plasma above radiator- bad ?
Discussion in 'Plasma TVs Forum' started by caw001, Jul 25, 2003.
  1. caw001
    caw001
    Thinking of getitng the panny 5, only place it can go in lounge is above big radiator. Am I going to damage the plasma ? Would putting some kind of shelf on the radiator help ?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Turn off the radiator?
  3. MikeIOW
    MikeIOW
    Aug 12, 2002
    156
    Leicester
    +4
    From what I've read (& I'm by no means an expert ;-), if the heat could 'melt' a candle where the screen is then this is ABadThing(tm).
    If not, should be okay.
    I would personally probably put a shelf & then ensure the radiator was only ever on low (I'm sure the heat from the plasma would make up for it ;-)
    cheers
    Mike
  4. JH4
    JH4
    May 6, 2003
    2,420
    83
    +264
    A typical heat output for a Plasma is 370 Watts and an operating temperature of up to 35 Deg C.
    Regards.
  5. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Turn the radiator off. The plasma will generate enough heat to compensate :D
  6. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    A shelf is a good idea, as it deflects the direct heat away, and it provides a place for your centre speaker to sit!:laugh:
