ddaddy,
My plasma is indeed mounted over the fireplace. I rarely use the fire, but also the fireplace surround is quite wide and deflects much of the heat.
One suggestion I've seen is to put a candle above the fireplace. If the candle is softened by the heat then it is probably not a good idea to put the plasma there.
James
