plasi help
Discussion in 'Plasma TVs Forum' started by Garrymol, Feb 3, 2005.
  1. Garrymol
    Garrymol
    Feb 3, 2005
    43
    Wirral
    Hi,Guys,
    could you advise what i will xtras i will need if i buy pannie screen only.
    my current setup has samsung digi box,panny dvd recorder,and bose home cine,ie dolby digital.
    Await your hepl eagerly,,Cheers Garry.ps panny iam thinking about th37pw7
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    welcome garrymol
    waht model is the DVD-R if it is a x5 series ie E55/E85 etc then you will need a component board.
    if it is a X0 series, E30,E50, HS2 etc then you will need either a JS RGB>VGA or a scart board (is samsung box ntl/telewest?) if sop connect Samsung>DVDR>screen via method appropriate to your recorder.......
    PS there are about 30 ways you could do this this, whjat i ahve posted above is my tip for cost V prscticality
  3. Garrymol
    Garrymol
    Feb 3, 2005
    43
    Wirral
    Thanks for reply.dmr e50 ram recorder,by the way what screen would you buy ?.
    Thanx,
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    probably a panny mate Cable>E50> either scart board or JS RGB>VGA boc then to panel......
