delta_42
Established Member
Just taken delivery of some new kit, I'm going to be doing some experimenting with an all-purpose box.
The idea is for a box that can run a TV backend, XBMC front end and also hold a few TB of media.
I've already got a server, which is running Windows Server 2012 Essentials, but I want to seperate my home media stuff from my business stuff.
Also I wanted to play around with some AMD tech as I've been mostly Intel for several years. I've got a couple of Brazoz/Hudson based HTPCs, but wanted something a little meatier.
So... the build is looking like :
Case : Custom case manufactured by Lian Li, based on the PC-Q25, but slightly bigger and capable of taking 7 x 3.5" drives in hot-swap racks. It's one of a batch of engineering samples I had made for a project that didn't come off!
Motherboard : Asrock FM2A85X-ITX - Skt FM2 ITX board, a great fit with my case as it has 7 SATA ports on an ITX board!
CPU : I went middle of the road and got an AMD A6 5400K, dual core.
System drives : Undecided about a system drive, depends what OS will be on there. If its Linux based, then I just picked up a 16Gb SSD which will do nicely.
Data drives : 4 x 3Tb WD Red
TV tuner : dual DVB-S2 card
PSU : BeQuiet 300W 80Plus
The idea is to have a play around with various TV backends, Mythbuntu (which will be fun as my Linux skills extend to spelling it!), MediaPortal and others, with XBMC as a front end.
Eventually, if I get it working, I'll swap the tuner out for a quad tuner, maybe eventually go for a larger system with multiple quad tuners based on an mATX board.
