Planet of the apes R1
Discussion in 'Movie Forum' started by Len, May 7, 2001.
  1. Len
    Len
    Does anyone have this... If so what is the transfer like... and how about the audio... Classic film but is it worth buying on dvd?
  2. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Is it worth getting? Short answer: YES. Longer answer: Read my review HERE
  3. koejap
    koejap
    Try region 4 it is anamorphic,plus pal. :p
  4. Guest
    But the R4 is from an inferior print.
    R1 is from more or less totally clean print (restored)
  5. Adam Barratt
    Adam Barratt
    Aug 9, 2000
    170
    16
    New Zealand
    I've compared the R1 and R4 versions, and would definitely go for the R4.
    Both are sourced from very clean prints, although fine grain and minor artefacts are more visible on the R4 thanks to the higher resolution of PAL and anamorphic enhancement.
    For my review of the R4 version click here.
    Adam
    [ 09-05-2001: Message edited by: Adam Barratt ]
  6. Len
    Len
    thanks folks... I'll probably go for the region one since it's compatible with all my dvd players.
