Planet Earth Hd-dvd Not Working
Discussion in 'Blu-ray & DVD discs' started by jayden28, Apr 24, 2007.
  1. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    tried all four discs on my 360 add-on not one works i just get the bbc hd logo after that nothing:mad: has any one else used this on the 360 add-on.
  2. shilv
    shilv
    Nov 20, 2006
    337
    28
    A Town called Malice
    +54
    I have this waiting at home so I will check and post back. Have you had any problems with any other HD DVDs in the add-on?
  3. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    only with relentess eneimies & that was a wildlife hd-dvd as well.
  4. dreamfish
    dreamfish
    It better be working!! I wanna watch when I get in. Surely if the BBC logo loads...the disc sort-of works?
  5. featherhall
    featherhall
    Jan 6, 2006
    7,851
    4
    3
    Scotland
    +1,999
    thats strange Jayden. If you get the logo it is very unusual. Mine works with the add on fine. If your other discs work fine then I would ask for a replacement as it wont be the player.
  6. Rawlo
    Rawlo
    Mar 9, 2005
    96
    +8
    Just done a quick test and it is working fine on my 360. :thumbsup:
  7. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    just emailed the bloke i ordered it from to asking him to exchange it for the blu ray version instead.
  8. Peter Galbavy
    Peter Galbavy
    Is you 360 permanently networked ? If not, I suggest trying that - even small title specific updates may matter...
  9. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    i will try that now,thanks.
  10. shilv
    shilv
    Nov 20, 2006
    337
    28
    +54
    Yep, mine's working fine too.
  11. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    thanks peter just done the update & it works fine & it looks out of this world on my pioneer 42"oxd,cheers bud:clap:
  12. Peter Galbavy
    Peter Galbavy
    You're welcome. Mine just arrived and looks as stunning as expected on the XE1 + 52" Sharp :) Now for an evening of PE.
  13. Tejstar
    Tejstar
    Dec 4, 2002
    22,999
    London
    +1,151
    You scared me for a minute as I was just about to go for the HD DVD version! So I take it the add-on plays this fine then?
  14. jayden28
    jayden28
    Mar 9, 2007
    1,220
    +60
    yep plays just fine now after the update.
  15. drew009w
    drew009w
    Dec 16, 2006
    14
    Hi i have just got my planet earth hd and its not working on the 360hd aswell,i just get the bbc logo.any help please..:mad: thanks
  16. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Get it online so that it can pull down any updates that are necessary.
  17. drew009w
    drew009w
    Dec 16, 2006
    14
    Hi thanks for relpying i have just got the 360 for christmas how do i go online for updates,do i just plug the 360 to my broadband and will it do itself..sorry for asking never done this before.thanks
  18. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Take a look here. :)
    [Edit] - I would also take the time to familiarise yourself with our XBOX 360 forum, which can be found by clicking here.
    HTH.
  19. shilv
    shilv
    Nov 20, 2006
    337
    28
    +54
    Has the update cured the problem you had with Relentless Enemies too?
    It never occures to me that some folk don't have their xbox connected to Live! as I am just so used to everything being hooked up to t'internet...
  20. Andris L
    Andris L
    Mar 11, 2007
    3,316
    3
    Home of the Brave
    +687
    OMG I just can’t believe peeps are using 360 offline… OK I will say nothing if some don’t have broadband at home but if you have internet connection and not connecting your 360 to network it’s something I probably would never understand :rolleyes:.
  21. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    solution at top of thread
