Placing a B&O Beosound Stage
picard25
This may seem like a silly question but that's the way I learn. Question = I am considering buying a Beosound but can not fit it flat on a wall but want to lie it flat under my Samsung TV.As this makes the speakers face upward instead of forward would I lose anything - sound,quality?
thank you.
keithwiggins
Its a good question. The Stage has been designed to either stand upright ideally against a wall or laid flat on say a shelf under the tv. The B&O App adjusts the sound profile of the stage to suit either position chosen.
My stage is currently laid flat under the tv. I purchased on ebay 4 sorbothane domes from ebay, so rather than the stage just sit flat on potentially a hard surface which could induce vibrations and colour the sound.
I have used the stage in both postions, laid flat and stood upright, there is a very slight and i mean very slight difference to the sound, its so slight i cannot determine which sounds better if at all. hope this helps . suggest you read up on user experiences on the beosound stage thread on this forum. The sound quality is spectacular in every sense we even have ex Ambeo owners, who have moved from that product due to issues they endured who are more than happy with the performance at more or less half the price.
picard25
Thank you.I could not have asked for more in a reply especially as I had never thought,nor heard,of these domes.
keithwiggins
Your welcome.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
