Placement Question...again :)
Discussion in 'Home Cinema Speakers' started by Kootuu, Jan 13, 2004.
  1. Kootuu
    Kootuu
    Nov 18, 2002
    772
    +23
    Ok just about to purchase my first home cinema set up, now, need some help on placement of things before I get going.
    Below is a picture of my room.
    [​IMG]
    Now, there is room above the bed, shelves above the tv, no room above the wardrobe and room above the desk.
    Now as I see it, for my room this is the best placement? Oops just thinking I forgot to add the sub but I will put that between the bed and tv most likely(only place to put it).
    The rears will be wall mounted, the fronts might also, depends if I can get some stands.
    Is this the best option for me? Or are there alternatives?
    Cheers,
    Chris
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Looks ok to me. :)
  3. Kootuu
    Kootuu
    Nov 18, 2002
    772
    +23
    Cool, just worried that I am going to have a very tight sound area, but I suppose it's the best I can do for the layout of the room, can't move things around.
