A couple of questions for you guys 1. Is it ok if my surrounds speakers are about 4.5 feet above the listener's ears, I have been told that is best to put them 2-3 feet above the listeners ears, why 2-3 is best? I mean what will be a problem if they are put higher?I am refering at bi-polar surrounds speakers which will be placed on the side walls. 2. I was told that the surround speakers should be also be 2 feet from the back walls, well due the usual sofa problem , the distnace can only be 1 feet from the back wall, again what will be that be a problem if is only 1 feet from the back wall rather than 2 feet. 3. The surround pack will it be ok if is on the same height with the surrounds? I was told that that it should be on the same height with the center. Thanks in advance Pavlos Ps I know that the above questions were discussed before but I failed to find explanations of the reasoning , ie why for example,it should be 2-3 feet rather than 5 feet above the listeners ears
This is an interesting article (disregard the Yamaha review) about speaker placement. It may not answer your exact questions but it might offer some assistance and food for further thought? Regards Jim http://www.hometheaterhifi.com/volume_7_3/yamaha-rx-v1-receiver-7-2000.html
