ianlecompte
Can anyone help ?I am currently using jpw rear surronds(mini monitors)but have alimited amount of space for placement.My sofa sits under the stairs so my rears are just either side of this and at about the same level..Because of the under stairs coming down i cant get the left any higher.should i perhaps lay them on their backs ?i have heard this is sometimes an option but one i would rather not do.apart from moving the whole room around(my wife would go mad)is there any else i can do.they are also right next to you in the seating position,so should they toe out or be facing each other across the back of the room.i would be most grateful for any help on this matter.
happy listening and watching.
ian
ian
