Placement of Ceiling Speakers for Background Sound
Discussion in 'Home Cinema Speakers' started by gerberpollack, Jan 8, 2012.
  1. gerberpollack
    gerberpollack
    Jan 8, 2012
    2
    My wife bought me the Z120 for the holidays. I've purchase speakers (2 CSR8 Two) for the living room. However, I'm having a difficult time determining the placement for the in-ceiling speakers. The challenge is where to place the speakers for quality listening while sitting on the L couch in the corner of the living room / entryway. Since I don't need direct sound in the entryway I plan to position the speakers on the one side of the room. The question is where?
    Andy
    Living Room | Flickr - Photo Sharing!
  2. PSM1
    PSM1
    Dec 20, 2008
    26,245
    +5,409
    Are these speakers for a 5.1 AV system or just background music? What is the Z120?
    Do you have 4 ceiling speakers to install? A bit more description of what exactly you hope to achieve, what sources you are using etc. may help to advice better.
  3. gerberpollack
    gerberpollack
    Jan 8, 2012
    2
    1. I'm installing a Sonos system.
    2. I'm using the speakers for background music.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,245
    +5,409
    If they are just for background music then spread them around the seating location that you want the sound. Probably 1 at the end of the sofa and then then other 2 towards the front of the room the same width apart.
