PL-Z91 turntable, power
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Guy, Jan 8, 2012.
  1. Guy
    Guy
    Jan 8, 2012
    Hello
    I'm fixing up old components to new powered speaker/amp. The turntable is part of a system I bought mid 80's which was powered from the DC-Z91 cassette deck/amp's DC 12v output. I am not now using the cassette deck/amp, so does anyone know of a particular transformer product that will do the job? The lead from the turntable has a plug on the end similar to one you might plug into an older nokia phone for charging, although wider diameter.
