davepuma
I connected up the Sky digibox to the PJTX200 using a Profigold PGV615 Scart>SVideo lead and all I get is a black and white signal. I have changed all the settings on both the Sky box (RGB/PAL) and altered between Auto/PAL etc on the PJTX200 to no avail. I have tried the connection using a video sender, direct to the Sky box and my DVD recorder. The lead is fine as I have connected it to my CRT TV and obtained a perfectly acceptable picture.
The PJTX200 displays "S-VIDEO MONOCHROME 50 AUTO".
Is the only way to get a SCART signal to the PJTX200 via a component converter? I have a 5m component lead and can go through my DVD recorder but it's hooked up to my amp for switching. I wanted to try and keep all the leads connected rather than disconnecting stuff and re-connecting them to the projector.
