PJ: White wall versus proper screen??
Discussion in 'Projectors, Screens & Video Processors' started by rjs1974, Jan 17, 2003.
  1. rjs1974
    rjs1974
    Hi guys!
    Am using a white wall currently with my HS10, and picture is still very good.
    For those who have used a wall then moved to a pucker screen, how much better would you say the image is on the screen? Is it just slightly better, or way way better?
    Similarly, has anyone upgraded to a "proper" component lead from the multi purpose lead supplied in the box? Does this make a marked improvement or not? And does using the 3 colour sockets at the rear of the PJ give better results that the multi socket?
    Many thanks.
  2. snocrash
    snocrash
    Dec 27, 2002
    103
    can't talk for the screen...
    But as for a difference in leads... Unless you are running more than 6ft ... There will be very little difference in one component cable to another.
    (Obviously the move from composite video to component is massive.. but i don't think this is what you were asking)
