PJ-TX100 and PAL Progressive (576p) - possible?
Discussion in 'Projectors, Screens & Video Processors' started by Beeblebrox_dk, Jul 21, 2004.
  1. Beeblebrox_dk
    Beeblebrox_dk
    Hiya :hiya:
    I have got my PJ-TX100 for about a week now and I'm a very happy camper :laugh:
    Only issue is that it doesn't seem to accept PAL progressive scan :eek: .
    I can feed it both PAL/NTSC over S-Video, detect/shows ok :smashin:
    I can feed it both 480i/576i over component, detect/shows ok :smashin:
    I can feed it 480p over component, detect/shows ok :smashin:
    If I feed it a 576p over component it says 'No input detected on component!' :mad:
    Can anybody in here positively confirm that the TX100 will detect, accept & show a PAL progressive (576p) signal via the component inputs?
    I'm using my Denon DVD-2800 mk II to feed it with!
    :lease: help me as I'm slowly going nuts about this!
    -Claus
  2. dazz111
    dazz111
    Dec 11, 2002
    16
    :thumbsup: 576p working fine for me through component from an arcam dv88+.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Worked fine on several units here!
  4. Beeblebrox_dk
    Beeblebrox_dk
    Thanks guys :), it must be my DVD, then!
    edit: 2004/07/22
    I have just got confirmed that my DVD-player isn't capable of playing PAL progressive scan with the current firmware version. I have ordered an upgrade from the local dealer very soon I'll be the happiest man in town :D
    -Claus
  5. tincupuk
    tincupuk
    Hi Beeblebrox
    Can i just ask if the picture in your opinion is good and how bright would you say it is please ?
  6. Beeblebrox_dk
    Beeblebrox_dk
    As for picture quality I will say very high :thumbsup:! Some people are complaining about a bit of VB but I see absolutely no trace of VB on my unit. With a 82" (206 cm, diagonal) screen and a a 10,2' (3,1m) viewing distance I don't notice any SDE either. The dark level is impressive but not nearly as dark as eg. the toshiba mt100 (a DLP based unit).
    It is plenty bright for me. I have used it in a completely darkened room where it is almost too bright with Whisper/Iris 4 which is the lovest I can go and maintain all the dark details (lighting two candles solves this issue). Even with only light curtains and full daylight outside it is bright enough to make a viewable picture (but now we are talking Normal/Iris 10).
    -Claus
  7. tincupuk
    tincupuk
