PJ stand rather than mount, any recommendations?
U
UrbanSurvival
Hi all, I might be asking too much here but can anyone suggest a Projector stand that can be positioned between a sofa and rear wall (40cm gap) which can be 'hidden' when not in use; either collapsed or telescopic. Height of about 1.4m would be good, oh and lastly not too much £££ if poss. :)
Many thanks
spuddler
Hi,i bought this stand & it is well constructed & solid(better than pic's show),it has 3 legs on bottom at 120degrees to each other.It would fit in a 50cm gap,however if you tuck one leg under settee it would fit 20cm gap approx(and be nearly knock over proof,unless settee lifts up 2ft).Rest of specs in link.I got it from here for £65 inc P & P,some quote it at about £100 now this could be correct if optional shelf/platform is included(but pic's do'nt always show this & still quote £100?).Maker is not quoted on websites i looked at but on box says,B Tech BT890(web site www.b-tech-int.com ).Its no lightweight but not bad,easily liftable.
http://www.chaseavdirect.co.uk/acatalog/Projector-Trolley-Portable-Lectern.html
Should be able to put some packing on platform if you want a bit more height i got some elastic straps to hold projector on securely,you can buy elastic from Haberdasheries if need be & make your own.
Cheers BOB
