PJ Screen extension
Discussion in 'Home Cinema Building DIY' started by Daddy arcanjo, Mar 6, 2013.
  1. Daddy arcanjo
    Daddy arcanjo
    Nov 16, 2010
    9
    Offered myself a new pj and now there´s a little problem, the screen needs an extension coz i have a tv on the wall and i need to deviate the pj screen at least 12cm from the wall otherwise the screen will toutch the tv obviously :D
    So already made a search on the web but so far no extender detected for what i need, i guess i have to do some DIY i just don´t know where to start and i really need some ideas/help
    Thx in advance
    Daddy
  2. k18dan
    k18dan
    May 27, 2006
    87
    Could you not make up something yourself with some wood? maybe some cut down blocks of wood painted the same colour as the wall?
  3. adam81
    adam81
    Oct 9, 2005
    674
    28
    coventry
    +34
    Yeah I just screwed a couple of bits of 2x2 together, making it stick 4 inches off the wall with mine.
    Fixed these to masonry with rawl plugs, then simply screwed the screen to them using wood screws.
    It was all boxed in anyway so not viewable once it was done
  4. Daddy arcanjo
    Daddy arcanjo
    Nov 16, 2010
    9
    Thanks guys the wood stuff dint passed trou my mind, i was only thinking in some metal brackets but yeah wood makes all more simple to acomplish.
    Thx for the help
  5. bow79
    bow79
    May 23, 2009
    881
    28
    Leeds
    +81
    L shaped metal brackets are very cheap and come in differnt sizes usuall grey. Or just go round BQ or somwhere and look for insperation.
