Quantcast
pj screen advice please
doubledrat
I am looking to buy a motorised 16:9 projector screen and I wonder if I can get some advice from you guys.
I will be using an LCD projector (if that makes any difference)
I want about 80 to 90 inches wide
I cannot mount the screen housing in the ceiling, so I would like it to be as low profile as possible
Can I have recommendations please on both make and supplier?
Bob
PS I would like the screen to be automatic. i.e. I would like it to go down when the projector is turned on and up when the projector is turned off. Do I need to look for anything special to achieve this? Or would I be better off with a screen that accepts IR? I have a pronto learning remote. (however seeing costs of an extra £250 to add remote control seemed OTT!) What about fixing at which point the screen is considered fully extended? Is this a standard feature of all screens?
PPS I have seen some tensioned screens. I presume this is to stop them wrinkling. First of all, do they work? Secondly, are they necessary?!
ani4ani
Hi I have just taken receipt of a slimline240 from DRH Screens
www.drhscreens.co.uk
this had the smallest profile of all the ones I looked at 6 x 6 cm.
They sell a remote control [RF] for £99.00
Screens 173 x 81 = 352 delivered rising to £442 for their 231 x 130.
The amount of extention is adjustable on a microswitch and is fixed at whatever you set it at
I am pleased with my screen
thx
ani4ani
Matt 4 me
Hi, I took the Matt. I already have two manual screens, [4:3 & 16:9] one high gain & one matt. Tbh I have never really seen any major gain [no pun intended]. I have been happy with the Matt. I guess as projector brightness has improved and my sitting position is direct on, it has not been too much of an issue for me
thx
