As with anything like this, you've got to assume worse case scenario.
Looking at the brick bond, it's not much of a bond. The bricks should be staggered halfway across each brick but that's just one point, going back to worse case scenario again, imagine the extreme force pushing down on those concrete blocks and someone accidentally pushes a wheelbarrow against the corner of a brick with the poor brick bond?
Once one brick has shifted you've created a weak spot and the whole thing could well fall. It's a bit high for its width really plus the bricks look a little like flamingos legs stood there. Imagine how much stronger it would've been if you'd have laid the same concrete blocks flat with the largest face of the brick against the base.
A very quick Google also suggests that the top would be better with a reinforced steel and concrete slab. Constructed using shuttering.
Not knocking your work and if I'm honest, it would probably be OK but is a probably good enough?
It's a tough call with what to do with it to strengthen it. I've half a mind to say block the front off and fill with concrete and rubble. At least it won't topple over then.
