Pixel T80 Stands - No bracket to connect to speaker
fixtures_man
got a pair of wharfedale 9.0s and a set of pixel t80 stands for christmas. have the stands built but there in no bracket or screws to connect the speakers to the stands. they dont just sit on the stand do they?
Hudson123
They do, speakers should hold their own on the stands however i believe its recommended to use a small amount of blutack under them to better secure them if you're worried about stability. You should have got 8 gel(or something) pads that go on 4 corners of the stand for the speaker to sit on.
fixtures_man
cheers mate - will try a bit of blutack
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
