Pixel Plus in a box?
Discussion in 'Projectors, Screens & Video Processors' started by Only777, Oct 25, 2004.
  1. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    I'm wondering if there is anything that produces an image as smooth as pixel plus.
    I have a Samsung LCD tv and would also like to take advantage of the higher resolutions this TV can produce.
    Would something like the Iscan smooth out movement? or is there any PC program that can do it?
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    If you want to do it via PC then you have a number of options - see http://www.pluggedin.tv/sweetspot/support/faq.html#2 for more information. Its pretty much accepted that SweetSpot is the best real-world PC solution.
    A standalone video processor will do a great job as well of course - whether or not you go for a standalone or a PC based system depends on how important "instant on/ease of use" is to you versus the fact that a PC allows you to turn your display in to a multi-media system.
    if you need any more information then drop us a line.
    regards
  3. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,468
    64
    Norfolk
    +223
    Personally, if my scaler (hardware or PC based) produced an image like pixel plus, then I'd demand my money back.
    The Iscan is a good choice. A PC with a suitable capture card and DScaler will also work effectively.
  4. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    Pixel plus, the "Marmite" of digital processing :)
    Is a PC with a sweetspot card as good as the Iscan?
    Will either solution create the smooth pans of Pixel Plus?
  5. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    883
    Lancing, West Sussex
    +73
    It's worse than that ! At least with Marmite you either love it or hate it. With Pixel Plus you love it one minute, on one channel, and loathe it the next. It's too source dependant, and therefore inconsistent. It's driven me mad since March when I got my Philips Plasma. Will be ordering iscan HD today to (hopefully) sort problem once and for all. Just wordering what to do with the Pixel Plus media box - maybe useful as a door jam ?
  6. philipb
    philipb
    Mar 6, 2002
    2,087
    63
    Swindon
    +172
    All this talk of Marmite and jam is making me feel hungry.
  7. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    What connections does the media box have?
  8. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    883
    +73
    4 scart (1 RGB / Composite, 1 RGB / S-Video, and 2 Composite only.
    1 Component (Y Pr Pb)
    1 front input (camcorder etc.) Composite / S-Video + 2 Ch audio.
    1 VGA input
  9. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,468
    64
    Norfolk
    +223
    I use Sweetspot+Dscaler with my BD801s. It is good. On film based material with 2:2 pulldown, it's comparable to the Centerstage CS-1, without any of the sync instability hassles. Video deinterlacing is pretty good. Since I use an X-card and also indulge in WMF-HD playback with zoomplayer-pro, I'm quite happy to use a PC as the hub of my set up.
  10. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    Will it work with other displays? or just philips?
  11. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    883
    +73
    I really don't know, but no doubt others on this forum will know more than me.
  12. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    What advantage does the sweetspot card over say a normal PCI capture card that has s-video in?
  13. dgc
    dgc
    May 1, 2003
    216
    You're not just limited to composite/s-vid. It also captures RGB & component.
  14. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    SweetSpot also now has an SDI input option, so you can connect up suitably modified DVD players or set top boxes (e.g. Sky) to bypass analogue inputs completely for those sources.
    no, I didnt say 'sauces' :)
    my personal view is that I also dont like pixel plus, indeed many of the video processing modes built in to high end TVs just look hideous IMHO, with loads of blocking and posterising.
