I have a Philips 32" 9528 P+. When I switch it to double lines, the picture flickers noticeably. (I'm not sensitive to 50Hz flicker) This is the 2nd set I have had, the previous returned due to poor geometry. I don't recall noticing the flicker on my previous 9528, although I hadn't used it much as I only had the set a couple of weeks. I do recall checking double lines mode whilst watching part of a football match and I thought the quality was good, not that much different from the pixel plus mode, but the movement of the ball looked more natural. I am assuming this new one is faulty and intend reporting it, but I read another thread today( 50Hz) and someone mentioned the same flickering with double lines mode.
Can other P+ owners help me. Is the flickering in double lines mode normal. I've only had the replacement set a week. Lastly can anyone explain what double lines does. The manual doesn't give a lot of information.
thanks
thanks
