pixel plus 2
Discussion in 'Televisions' started by andya, Jul 5, 2003.
  1. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    does anyone know if the new sets have solved the problems that people were having with the older models.i know there was a lot of problems with the pixel plus but i liked the design and also the way camera pans were extra smooth.i was going to get the panasonic pd30 after being amazed by its quality .but some people have said its not so good with game consoles just waiting to here there replys
  2. scooby do
    scooby do
    Dec 11, 2002
    1,760
    48
    +37
    Smooth camera pans on a Pixel Plus set, you must be joking, mine stutterd and paused all over the place. Yet Philips tech support (who viewed the set in situ)told me it was peforming normally and within spec.
