Piping Telewest cable round the house
Discussion in 'Cable TV & Virgin Media TV' started by Eddie Eddie, Mar 24, 2005.
  1. Eddie Eddie
    Eddie Eddie
    Mar 24, 2005
    2
    Has anyone successfully piped Telewest cable round the house and been able to control the box with the remote from several places. I am told that it uses irDA and almost all distributing amplifiers will not work as they do not send the irDA signal back.
    Can anyone help?
  2. Brava 210
    Brava 210
    Feb 17, 2005
    2,446
    116
    Bristol
    +908
    aei digisender gold will work-but costs £120 :suicide: :suicide:
  3. KERRYBR
    KERRYBR
    Mar 17, 2005
    94
    why not the normal digisender at £80 from argos?
  4. JRH
    JRH
    Because most cable boxes (both NTL and Telewest) use irDA remote control signals. :(
  5. Cliff
    Cliff
    Mar 17, 2001
    4,692
    137
    Kent & overseas
    +1,841
    Many ways to skin a cat!
    I use the red eye converter. Just stick it on the cable box and it converts normal infra red signals to Irda. You can then use a universal remote to control your TV and cable in your bedroom using a cheaper video sender or coax and remote sender.
