Piping Sky around a house?
Discussion in 'Sky Digital TV Forum' started by Squiffy, Jan 20, 2004.
  1. Squiffy
    Squiffy
    May 23, 2002
    11,841
    Ashford, Kent
    +5,108
    Currently we have Sky+ in the living room, with a video sender to the Kitchen TV, and regular Sky in our bedroom.
    We've just agreed a price to buy a new place. :clap: The house has co-ax piped to most of the rooms, and I was just wondering what we could do to piggy back on this?
    We will keep Sky+ in the living room, and want the second Sky box to be piped throughout - can we do this? What would we need to do?
    Any help much appreciated.
    Additional question just came up.
    There is going to be a month or so gap between moving out of our current house, and going into the new one. (Don't ask - it's a bit of a saga!). I'll end our current subscription when we move out.
    What would be the best way of getting a new subscription? e.g. deals on getting new boxes (that I can flog on ebay), getting vouchers for being "introduced", cheap installation (there is already a dish, we already have boxes), etc.
    Thanks again.
  2. Fernsehman
    Fernsehman
    Make sure the cable is the proper double-shielded stuff or you could run into problems with the "magic eye" and with "Freeview terrestrial" if you get it.
    You can download an eBook "Piping TV Around the House" that might help.
    Why not simply suspend your Sky subscription? They also do a reasonable deal for house movers in terms of installing a new dish, LNB and cable.
    You can't take your existing dish unless you agree it in writing with the new owners of your house ("fixtures and fittings").
    Fman
  3. Squiffy
    Squiffy
    May 23, 2002
    11,841
    Ashford, Kent
    +5,108
    Thanks for the link - will take a look later.
    We don't need a dish. We're leaving ours, but the new house already has one.
    I'll talk to Sky about suspending our account, rather than ending it/getting a new one.
  4. windfall
    windfall
    Oct 19, 2003
    2,407
    48
    LFC Kop End
    +60
    We just moved an have the following solution doing away with the video sender.
    Aerial down to loft into digital amp. Cable from RF2 on Sky+ up into loft into digital amp. Digital amp has 4 outputs to each aerial socket around house. Each aerial socket has remote eye and sky+ remote even on my PC!!
    Its the simplicity thats great and no need for expensive video relays.
    Hope this helps.
    Tone
  5. HDPete
    HDPete
    Jan 15, 2004
    281
    Ringwood, Hampshire / Dorset Border
    +14
    Can you recommend the digital amp so that the sky remote eye will go through without bypass filters.
    Pete.
  6. windfall
    windfall
    Oct 19, 2003
    2,407
    48
    LFC Kop End
    +60
    Hiya
    I dont know what make mine is because the aerial guys from a northants based arial company wouldnt show it to me when they fitted it, but at maplin you can pick them up quite cheap.
    Look up code L24AG or Aerial Amplifiers and you'll find them.
    www.maplin.co.uk
    Remote eyes are available from ebay a lot cheaper then from maplin.
    Hope this helps
    Tone
  7. hodgey20
    hodgey20
    Feb 22, 2010
    2
    Can anyone help?
    i've purcahsed the L25AG splitters, and am having trouble with it. just wanted to check i wasn't missing something simple.
    I'm trying to get sky in my bedroom (run from my Sky RF2 output) and other rooms around the house while still recieving freeview on each tv. each tv has built in freeview, and it work fine until i try and recieve my sky signal, then no freeview, just sky.
    do i split the input to the UHF input (sky and aerial) or do i use seperate inputs VHF and UHF or is there another way.
    I'm sure i've just missed somthing or have made a small error somwhere, but its driving me mad. any help please?
  8. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    You are aware that your bedroom TV's should be using their analogue tuners for Sky and their digital tuners for Freeview?
  9. hodgey20
    hodgey20
    Feb 22, 2010
    2
    Yeah I recieve sky on anologue, but it cuts out my digital signal, not sure where I have gone wrong in the setup. i have an LG TV if that makes any difference.
  10. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    Then change your Sky box's RF output channel - search on here for how to do that.
  11. homerslazy
    homerslazy
    Feb 20, 2010
    Hey ...me and my brother have done more or less exact same.....but both of us have snowy/grainy pics on tvs 2 kitchn and 3 bedrm....i have tried changing RF Settings without success.....any ideas?.....my brother tried to add some kind of booster to the back of tv to see if that would help but then his magic eye would not work?:confused:
    cheers:clap:
  12. lovenkrands
    lovenkrands
    May 19, 2006
    4
    can anyone confirm if changing the rf output channel worked, I have the same problem?
  13. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    Then try it!
    Make sure to re-tune your TV everytime you change RF channel on the Sky box.
