Pipex adsl
Discussion in 'Networking & NAS' started by chilpillphil, Jan 15, 2004.
  1. chilpillphil
    chilpillphil
    i spoke to someone at pipex, i can sign up using solo card so i shall, I was surprised to here its a 12 month contract,
    can i ask, i want to share my new adsl connection with my sister's pc, and want to be able to use them without both being on at the same time,
    what router/modem do i need?
    i ideally want an all in one, what shall i get?
    Andrew
  2. DJW
    DJW
    Aug 29, 2002
    965
    16
    HI
    I use Pipex & after trying 3 diff types of Wireless I can recommend D-Link......I bought the DSL-604 (around £100) all in one (modem/router/wireless) & it works faultlessly with great distance ability. Currently share PC & Laptop through it no probs, plus have even used PS2 Online :)
  3. tonyb
    tonyb
    May 14, 2003
    96
    Kent
    Just looked at the Pipex website here for the details of their residential 512k service. The website states that the minimum contract period is 1 month, with a canellation charge of £58.75 if you choose to cancel within the first 12 months of having the service. So it might be worth checking again with pipex to see exactly what the situation is....
    On the subject of routers, you're probably better off buying a router that incorporates a built-in adsl modem. Take a look at Netgear's website. Netgear products are available from most stores, and you can expect to pay between £60 and £100. Wireless will remove the need for running cables everywhere, but will increase the cost.
    Tony
  4. chilpillphil
    chilpillphil
    im prepared to go for a 12 month contract, ive been with freeserve anytime for the past 12 months, and its gone so quickly,
    ill have a look, how do i know the modem is in the router, im not sure wether ill get wireles,, depends if my mum will pay the difference.
  5. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Good choice Chilpillphil. I've been with Pipex ADSL for over 2 years now and will happily continue to do so. Not had any problems. :smashin:
  6. chilpillphil
    chilpillphil
    cool, when i phoned up earlier they seemed good, and were very quick
    I want to order a router from aria, which one shall i go for http://www.aria.co.uk/productsList.asp?Category=28&Submit=submit
    if these are over priced, where should i buy one from,
    not to bothered about wireless, just a 4 port router thats fairly cheap
    thanks
  7. chilpillphil
    chilpillphil
    can i also ask, its not gonna affect my phone line is it in anyway atall, my mum would go mad lol
    what if they activate it before i get the filters?
  8. dannyc
    dannyc
    HCKing is selling cheap adsl router over on the classified if you need one.
    Dan
  9. chilpillphil
    chilpillphil
    its very quiet, can someone give the all clear so i can go ahead and order.... please
    regards
  10. chilpillphil
    chilpillphil
    ok, well i just ordered, it said please note we do not acept solo,
    i selected switch, and put in all my solo details
    do you think they will process my order?
  11. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    They'll process until it comes to payment authorisation... give them a call or email them to sort it out. You won't need filters until you connect up your router/modem. Make sure that you either filter centrally or that you have a filter for every device connected to a socket (except the router/modem).
    Hope this helps (sorry I didn't notice the thread before). :)
  12. chilpillphil
    chilpillphil
    bugger, they canceled my order :'(
    ill have to ask my dad, and one know a previder that you can pay a year unfront or that acept solo?
  13. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Pipex allow a year up-front or you can ask to pay by direct debit (check that your bank account allows this).
  14. chilpillphil
    chilpillphil
    they said, they cannot acept my card, and you need to use switch/ mastercard or visa
    im gonna order giointernet, £19.95 p/m for 512k plus £59.99 activation,
    i will start saving back in just over a year,
    Has anyone used www.giointernet.com?
  15. DJW
    DJW
    Aug 29, 2002
    965
    16
    As I use the internet for connecting to work for up to 10hrs a day I researched all the ADSL guides for best ISP. Pipex came out top in most ( http://www.pipex.net/images/dial/headers/tb1news.jpg) plus has a good track record over the last few years.
    I've been using them for approx 6 months now & have never had a problem. Is it really worth saving a few quid over a year, to possibly end up with the unknown ? Saying that its free activation with PIPEX if you have your own modem, & would take 18 months to recoup costs with your latest option.
    Personally I went for the modem & 2 filters @ £17 & then sold the modem for £30 on EBAY....meaing I was £13 & 2 filters better off:) Remember any external router you buy will inevitably be ethernet connection, whilst most modems offered by ISPs are USB only. Go for the all in ones :smashin:
  16. chilpillphil
    chilpillphil
    yes thats good, pipex sounds great, but they will not accept my card, therefore, i am inable to order it.
  17. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Steer clear of Gio... they have quite a poor reputation. Check out the message boards at www.adslguide.org.uk before you make a decision ;)
  18. chilpillphil
    chilpillphil
    well i carnt get pipex, people have different oppions of services,
    if you can find another provider that exept solo i will choose them
    if not, im stuck with gio
  19. pacemaker
    pacemaker
    Aug 31, 2003
    547
    +17
    pipex are excellent been with them for 2 years and no probs
    as for sharing access i use a non-wireless lan which bought recently , its an edimax adsl router and paid about £50
    be carefull as not many so called adsl routers have a built in modem, which then requires a special rj45 modem costing in axcess of £70, so what seems to be a good buy originally works out expensive, this applies to wireless and cable ones
    best buy ive seen is from Scan Computers http://web6.scan.co.uk/Products/Info.asp?WPID=70361
    £47
