PIP on the Sony 32FX66...
Discussion in 'TVs' started by MattDX, Feb 14, 2003.
  1. MattDX
    MattDX
    I know it's only got 1 tuner so one of the PIP feeds has to be from a local source (DVD, Console, Sky Box etc) but can I get both feeds from local sources i.e. console and DVD on screen at once?
  2. afleming
    afleming
    Feb 6, 2003
    47
    manchester
    i am pretty sure you can, because all of my viewing is through the av inputs as i dont actually use the tvs tuner or aeriel socket and i have had pip working. To me this is better than actually having two tuners that i wouldnt use either ofthem.
  3. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Yep you can.
    You specify which AV input the PIP is to be.
    Then you can have the console on & have a dvd/sky/video/tv on the PIP.
    You can then switch between the two.
    Great! :smashin:
  4. MattDX
    MattDX
    excellent!
