PIP help needed on dual-tuner LCD TV
Discussion in 'LCD & LED LCD TVs' started by ck_1804, Aug 21, 2005.
  1. ck_1804
    ck_1804
    Aug 21, 2005
    just got the 30" Syntax dual-tuner TV and am hoping someone can help me with the PIP problem I have.
    I can get the small PIP screen to show up, but it only shows the same program as on the main screen. Since it is a dual-tuner TV I should not need the VCR to connect this.
    Here is my connection:
    wall cable to cable box (analog)in. Out from cable box to TV RF.
    I also have a Playstation and CD movie player connected via composite cable and S cable, bot work perfectly well on PIP.
    The only thing I cannot get going is watching 2 different TV programs.
    Does it have anything to do with the kind of cable box I have? Do I have to worry about A/V switches and such?
    I have both the main picture and second picture set to TV.
    I really would appreciate any help with this.
    Thank you so much.
