bluefoxtim
Hi...
On my LG 26LC2R I have PIP supported.
Whenever I press the 'PIP' button I get a picture in the bottom left hand corner with a tv and a red cross in front of it.
I looked in the manual and it says I need to be in RGB, HDMI or component...
I have a device hooked up via component, but this image appears regardless if i press the PIP on the component output or watching freeview through scart.
EDIT:
If I turn the component device off, and go into component display, the PIP function works and shows the TV in the background... if i then turn my component device on, the PIP will dissapear and the tv will just show the component display...
How do I get both?
ta
EDIT:
How do I get both?
ta
