PIP/Dual screen? (service menu) 32pf9976
Discussion in 'LCD & LED LCD TVs Forum' started by Amoanster, Feb 16, 2005.
Tags:
  1. Amoanster
    Amoanster
    Dec 13, 2004
    174
    +6
    I have accessed the service menu for my Philips 32pf9976 and have found a section that refers to the pip mode. It says:
    PIP/Dual Screen Yes No,
    and this is set to no and underneath it says
    TXT/EPG Dual screen Yes
    Now when i set dual screen on my set i can only get txt one side and picture the other. If i set the PIP/dual screen to yes will this allow me to have two different inputs showing on either side of the screen. I didnt want to set it to yes if it will affect my tv so i will wait for a response.
    Aaron
  2. Rob1698
    Rob1698
    This option is set to Yes in the 9986 which has 2 tuners.
  3. Amoanster
    Amoanster
    Dec 13, 2004
    174
    +6
    so does that mean if i set mine to yes it will make no difference? Do you have to have 2 tuners to see a second picture? Could you not have a digital signal and one rhf signal from the tuner?
    Aaron
  4. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    bump
  5. philipsdude
    philipsdude
    How does one access the service menu?
    Thanks/ Jonas
