pionner pdp434 speakers
Discussion in 'Plasma TVs Forum' started by danbassy, Jul 4, 2004.
  1. danbassy
    danbassy
    Jan 12, 2004
    65
    What are the speakers like and could they be used as a centre speraker for a 5.1 dd setup?
  2. sirees01
    sirees01
    very good speakers on the 434.
    we were very surprised when first listening to sky movies through the plasma speakers only.
    I suppose you could use one as a centre speaker if you wanted to.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That might depend on what you are used to. Personally I find them fairly crap, about the same as any reasonable quality TV speakers. Absolutely nowhere near the quality of decent budget cinema speakers.
  4. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    I would say that they are a significant improvement on normal TV speakers. I was surprised how decent they were - they make normal TV viewing a reasonable experience.
    However if you going for a dedicated HC then obviously there are a lot better speakers out there + you really should be looking to tonally match your front three speakers to create a seamless soundstage.
