Pionner 530 finalising?
sweetie
I am unable to figure out how to finalize a disk at a later stage than during the burning process. If I am recording onto a disc and try to finalise will it interrupt a hard drive recording if it's taking place? The message it gives seems to indicate that.
anna the dub
You can't finalise a disc whilst recording to the hard drive. Once the recording is finished, then you can finalise no problem.
bradavon78
I imagine it's the same as the 540 and if so it's in the Disc Options menu.
More than likely. I doubt it will let you get to the finalise option if it's recording.
