Pionner 360 Green Screen -
Discussion in 'Blu-ray & DVD Players & Recorders' started by weyland-yutani, Jun 15, 2004.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +103
    my pie and ear 360 causes RGB pictures to be tinted green :thumbsdow it does it with both R1 and R2 discs. when i step the signal down to composite, the green goes away. i've checked the connection and they are secure and in place. does anyone know what causes this effect and who's at fault, the player, the tv or the cable?
    it is rather infuriating :mad:
  2. angelislington
    angelislington
    May 14, 2003
    1,539
    Kent
    +235
    This sounds like you may have connected the player to a tv input that is expecting component video. Either that or your dvd player is outputting component (if capable) and not RGB. I'd double check these things first.
  3. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +103
    the dvd player is set to RGB and the tv doesn't have component enabled scart.
  4. angelislington
    angelislington
    May 14, 2003
    1,539
    Kent
    +235
    Have you tried swapping the SCART cable for a different one to rule out the cable?
