Pioner 575 Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Fonzerelli, Mar 9, 2005.
  1. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    My Pioneer 575 has snow between menus as you click one and move to another screen you get a snowy effect, also the picture quality has gone from great to pants :(
    The thing is this is the second 575 ive had this happen too the first one was replaced under warrenty, so im now starting to think this is either a common problem or its something i have done myself!!
    Anyone got any thoughts? has this happened to you?
  2. shodan
    shodan
    Dec 11, 2001
    12,160
    shoeburyness
    +7,784
    Before you do anything else, check and make sure all the cables are firmly pushed into the sockets!
  3. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    I did i even replaced them :)
  4. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Are you using RGB / Svideo / Composite ? What is the Pioneer set to do ?
    Eg. if your using RGB do you get the problem with other RGB sources, Freeview, SKY, Cable, Games Conoles...other DVD players ?
  5. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    Its set to component mate, i only have the dvd player with component. im using ti with my projector, i dont have the same problem with i use DVI/Sivdeo either.
  6. danrichmond
    danrichmond
    Mar 3, 2005
    22
    Sounds to me like another reason to stay clear from Pioneer's budget models. I have a brand new Marantz DV4500 in the classifieds section if you're interested in changing? It's brand new with full manufacturer's guarantee. Bargain too!
