Pioneers: AX3 vs. 2011
Discussion in 'AV Receivers & Amplifiers' started by skimber, Aug 27, 2003.
Tags:
  1. skimber
    skimber
    Dec 1, 2001
    205
    19
    These two seem to be around the same sort of price, but am i right in thinking that the 2011 is higher spec and the AX3 is the replacement for the 1011?
    Which is the better of the two?
    Thanks!
  2. RUWANDIGITAL
    RUWANDIGITAL
    The AX3 is the new one and is the same as the 1011.
    Wel,i gues that de ax3 will have some more extra features but no details are announced yet until the IFA in berlin.
  3. lukes
    lukes
    go for the 2011 :)
  4. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Yes I'd go for the 2011 too. Until it's no longer avilable the AX3 seems like it's a little lost in the A/V Receiver pricing world.
  5. skimber
    skimber
    Dec 1, 2001
    205
    19
    cheers. can anyone recommend anywhere that has the 2011 in stock?
  6. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    Creative Audio had them in stock when I put a deposit down on mine about 10 days ago.
    Big A
  7. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    The AX3 is a replacement for the 2011 not the 1011 (AIR Studios tuned etc etc) - not sure how they compare to each other yet though. However, Pioneer are no longer shipping this product except for the last backorders so you'll have no choice about it very soon!!!
    (we've still got one in stock ;) )
  8. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    how much?
    Phil :)
  9. Gomez
    Gomez
    Nope,
    the AX5 is the replacement for the 2011. The AX3 is indeed replacing the 1011.
    Both AX3 and AX5 will be tuned by AirStudios.
    Also check here:
    http://www.avland.co.uk/pioneer/vsxd1011/index.htm
    http://www.avland.co.uk/pioneer/vsxd2011/index.htm
    More information available tomorrow after having visited the IFA in Berlin. ;)
    BTW: Just got my 1011 and I'm stunned... :eek:
    Regards,
    Gomez
  10. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    The AX3 may OFFICIALLY be the replacement of the 1011 (i.e. same price point) but it has more in common with the 2011.
    Thus making the 2011 a 5star bargain!
    If you can find one, buy it cos it's not like retailers need to discount them to clear their shelves!!!
    :D
  11. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Big Adam - I wouldn't say so, it's basically the 1011 with the Auto-Setup procedure...
    Has same remote, connectivity & specs as the 1011.
