pioneer814, sony 795, denon1905 ??
Discussion in 'AV Receivers & Amplifiers' started by killabeez, Jan 4, 2005.
  1. killabeez
    killabeez
    Jun 29, 2004
    HI all
    Looking to put one of the above to go with my Mordaunt short premiere + speaker system but, with them all being a similar price wondered which would be the best purchase ( leaning towards the Pioneer at the mo )
    Sony 795, has buzzing problems ( possibly )
    Denon, not sure of the looks of the unit ? ( doesnt appeal to me,,sorry )
    Pioneer, well not much i can find against it, also there are plenty of suppliers have it in stock,
    Help please :rolleyes:
    Use will be mostly movies and watching music chanels
    Coupling it with:-
    pioneer 575 dvd
    panasonic e55 dvd recorder
    panasonic viera plasma
    ( hope that helps )
    Regards IAn,,
  2. Kazman
    Kazman
    Jan 14, 2004
    5,266
    Luton, Bedfordshire
    +139
    I'd go for the Pioneer, but saying that, all three are good amps.
    The Denon may suit the Mordaunt Short speakers a little better though, but I doubt the difference will be that noticeable. I'd disregard the Sony due to the sheer number of issues that have been flagged on it and continue to be flagged on it, I believe the buzzing issue is still on going.
    The Pioneer would also mean one less remote, as you could use the amps remote to also control the DVD player :D
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,962
    2
    +3,330
    Although the AX3 remote doesn't seem to control the 575 :confused:. I would go for the Pioneer out of those units although I would also suggest a look at the Marantz SR4500 as that is a very nice amp indeed.
  4. killabeez
    killabeez
    Jun 29, 2004
    Cheers for your valued input Kazman, geting rid of one more remote is proberly a big bonus point for the Pioneer :thumbsup:
    Also a big thankyou to 'tons of fun' but unfortunatly the 4500 is out of my buget :mad:
  5. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    From those three above, I agree with Kazman, the Pio would be the choice.
    Wasabi
  6. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  7. killabeez
    killabeez
    Jun 29, 2004
    Thanks for the surgestion Dfour, but at £211 for the Pio its just about reached my limit :clown:
    Could keep just adding £50 or so but where would it end,,lol.
    ( with a dam sight better Amp i hear you say :blush: )
    Cheers all,,,,,gone for the Pio and it should be here on Thursday, wish me luck.
    IAn,,
