pioneer xdp-x30r dap
GerOD
I have the above for approx 3.5 years.
A great little device.
Unfortunately, volume control has stopped working.
There is a dial on side of the device and a display on the device as the volume is adjusted.
This has stopped working, while I can turn dial no display appears and volume does not change.
Dial handles ok.
I have tried a factory reset and has not fixed the problem.
Any help, suggestions would be most welcome.
The device was quite expensive in the range of €300.
Many thanks,
Ger.
Steven
Senior Moderator
Ask the retailer to service under warranty? The unit will go to a Pioneer service centre or approved third party service centre
GerOD
Thanks Steven. Device is 3.5 years old doubt it will be covered under warranty.
I will check with pioneer.
LG CX Best Picture Settings
