remove stereo by inserting clips to each side.
these are the clips which are on the inside
remove stereo and remove cover to front of steeo. i think its held down by 2 screws. both at the back.
look towards the right hand side of the stereo if you are looking at it as you have shown in the pic and you should see a black spring push the spring towards the rear of the stereo and insert a cassette. That should sort it. Its almost ALWAYS a spring fault with these.
I used to have one in my in a 944
long long long time ago. poor man now
( i got married
