Pioneer whithout the media box
Discussion in 'Plasma TVs Forum' started by Glasgow Adam, Aug 30, 2005.
  1. Glasgow Adam
    Glasgow Adam
    Aug 30, 2005
    30
    quick query - I see the new pioneers come with a similar media box to last generation.
    I'm thinking of bypassing the media box and just linking everything though the amp i have my eye on and from there up to the screen with a hdmi/dvi cable. Does anyone know if this will work? Is there anything in the media box that actually affects the qaulity of the pictures sent through it?
    thanks for your help!
  2. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    If you're thinking of the 435 or 436 then you have to go through the media box. Direct connection to the panel will not work.
    The media box controls the screen and has the video processing onboard. This is not a disadvantage, you still only have one cable from the media box to the display. (it does have two connectors on each end though)
