Pioneer VSXD814 with DV575 combination ?
Discussion in 'AV Receivers & Amplifiers' started by jimbowley, Nov 10, 2004.
Tags:
  1. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I'm thinking of the above combination to feed my pwd6 plasma.
    My main reason for thinking of the VSX814 is that the remote will work the dvd player, and the dvd player is well thought of.
    I will get a netgem freeview box as well, so the VSX will switch those 2 component inputs (any extra sources will have to go s-vid to the screen and i'll have to switch manually).
    The above combo at £250 +£120 suits my budget, so unless anyone has anything bad to say about the VSXD814 ?
    thanks, jim
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
