pioneer vsxd812 set up
Discussion in 'AV Receivers & Amplifiers' started by harveydean_uk, Dec 15, 2003.
Tags:
  1. harveydean_uk
    harveydean_uk
    Using
    Pioneer vsxd812 to drive - Tannoy Revolution Centre, Tannoy R1's as surrounds
    Nad 319 amp linked by pre-out to drive Tannoy R3 Front Speakers
    All set to Large - Medium Sized room - I have set the speaker distances.
    However I have not performed the MCACC set up (apparently the 912 had a microphone to do this automatically)
    Will this process dramatically improve the sound? How do I perform the set-up without a sound meter?
    I have to say that I haven't been knocked dead by the sound - And I've listening to most settings - I prefer the "game" setting as it seems to boost all levels and make the sound come alive.
    Is there anything I've done wrong.
    I'm using a Philips DVDR80 with digital light connector to the Pioneer.
    Sound from the Sky Digibox is also very poor quality.
  2. harveydean_uk
    harveydean_uk
    I've reposted this message as I'm still unsure whether I need to perform a MCACC set up for the PIO.......
    ..........do i need an SPL Meter? Where can I get one?
    I've set the distances to calibrate the speakers - but now I need to adjust the volumes...
    ....are there other methods to do this?
    Ta in advance
  3. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    The 912 does have a microphone to do it automatically. you can try to do it with your own hearing, its probably worth it until you can get a spl meter. It is definatly worth buying one as to where you can get one from try doing a search on google or your favorite search engine.
  4. harveydean_uk
    harveydean_uk
    If I'm attempting to do it manually (by ear!) should I be getting the volume of the test signals to be equal?
  5. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    yes
  6. nictry
    nictry
    Apr 28, 2002
    5,422
    Kent
    +587
    I would highly recommend setting it up with an SPL meter, I recently got an 812 and felt it wasn't quite right with the balance between speakers front/rear and the sub, when I checked with an SPL meter I was way out on the sound balance when I set everything to balance it sounded far far better and I am well chuffed with this Amp I think it is great for music and movies (OK it is not >£1K material but for the money it is great value.
    Get an SPL meter you won't be disappointed!
  7. harveydean_uk
    harveydean_uk
    Thanks for that advice - where can I get an SPL meter - I've checked the web and all i get is meters at £1000 + for professional use............
  8. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    various sources, but analogue (preferred) are in short supply. Try Maplin. Check the frequency range goes low enough for the sub. Radio Shack have a new analogue coming soon, apparently. Expect to pay between £30-£50.
    I paid £34.99 at maplin for a digital spl, is brilliant, BUT doesn't claim to go below 300hz, which analogues often do. I still set up sub (got a reading) but it may not be accurate because it's outside the specs.
    But in reality, my sub gets adjusted a lot depending on time of day and presence of neighbours, so maybe its not too important.
    I got this one (now £54.99) for £34.99 on special offer. It makes the whole thing very easy (subuject to sub issue, above).
    http://www.maplin.co.uk/products/module.asp?CartID=031221235420429&moduleno=25671&Products
    But if you search this forum you will find threads with sources for SPL's in UK.
