Pioneer VSXD512S
Discussion in 'AV Receivers & Amplifiers' started by nathsea, Jan 21, 2004.
Tags:
  1. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Hi all,
    I`m thinking of buying the Pioneer VSXD512S from empiredirect as they have it on offer at the moment at £139.99, which seems like a bargain to me, but I haven`t been able to find out that much about it. Does anybody have one, or anybody have any ideas for an amp around the same price or up to £200 ?
    Many Thanks in advance
    Nathan
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
  3. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Thanks for your reply, are you saying then that I should go for the Denon instead of the Pioneer?
    Any other ideas?
    Nathan
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    No, not at all. Just answering your question when you asked if there were any others in a similar price range to consider. Another amp in your price bracket would be a Yamaha RX-V430 or a Sony STRDB790. The Sony is slightly over budget at around £229.
  5. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    Many thanks again for your quick reply, I have decided to take advantage of the interest free credit, and go fro the STRDB790 from Sony, as this seems to have all I want and more, and gets good reviews..... Unless of course any of you have a better idea?
    I also thought about the Onkyo TXSR501 but it appears to be that bit more expensive.
    Many Thanks
    Nathan
    :smashin:
