Pioneer VSXC300, noisy fan problem
CrumpetMan
Joined
Aug 12, 2002
Messages
107
Reaction score
Points
16
Just got one of these and after it's been switched on for about an hour I can hear a fan kick in. It is much too loud to put up with and can clearly be heard above the sound from the speakers. The fan stays on for 2-3 minutes but comes on again within the hour.
I checked the manual and it says nothing about a fan, just that it needs x amount of space above, behind and to the sides. I haven't left quite enough space above it, I think there is about 10-15cm and the manual says to leave 20cm. But to the sides and behind it is clear.
I bought this receiver because of it's slimline appearance, but if I need to leave a huge space all around it I might as well use my old chunky sherwood cause it will end up taking less space overall.
Have any other owners come across a problem with a noisy vsx300 or do you think it is a fault with the unit? I need to know if it is supposed to do this because if it does, I don't want one. If it is a faulty unit then I will send it back for a replacement.
TIA.
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
