T
Tobez
Ive got a Pioneer VSX 2011 with Air Studios auto setup, Ive been trying to get the sound correct with the sync of the mouths on DVDs etc. If i play it in the main room on a standard Kiss DVD player on a normal TV its fine, But if i play it in the cinema room on the amp etc, its out, Ive used auto setup but still same, I then decreased the distance to the speakers to minmun on them all and its still out ? I have my xbox on the amp also and its the same on that also.
Is there any settings anywhere else i need to change or twiddle for the sound to sync, it seems as though theres a small delay soemwhere But i change the distance but still same :/
