Pioneer VSX-D912 worth the money??
Discussion in 'AV Receivers & Amplifiers' started by Dom36, Sep 22, 2003.
Tags:
  1. Dom36
    Dom36
    Aug 26, 2003
    285
    Good ol' UK
    +6
    A simple question.
    Is the VSXD912 worth the extra £80 ish over the Pioneer VSXD812?
    Also Black is the prefered colour so the 812 has the advantage so far...
    Thanks for any help...
  2. luv ya jen
    luv ya jen
    think there basicaly the same only that the 912 has auto set-up havent heard the 812 but the 912 does totally rock
  3. binky
    binky
    Feb 10, 2003
    26
    3
    Oxfordshire
    not sure, but does the 812 have the same learning remote as the 912 ?
  4. Dom36
    Dom36
    Aug 26, 2003
    285
    Good ol' UK
    +6
    Ok got the 812 in the end and yea it does have the learnig remote which is very cool...
