Pioneer VSX-D812 and Banana Plugs
Discussion in 'AV Receivers & Amplifiers' started by Mark123, Dec 15, 2003.
Tags:
  1. Mark123
    Mark123
    Sep 20, 2003
    454
    Belfast
    +29
    Does anyone know if banana plugs can be used with the pioneer vsx-d812.
    I want to bi-wire my speakers an I think banana plugs will make the the wiring of the amp much easier.
  2. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    Yes. you need to remove the plastic thingy so that the plugs can go thru.
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    By "plastic thingy", I think overfloe means the bung in the middle of the speaker terminal - on my old 811, they came out easily with a small headed screwdriver.
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    What has been your feelings towards the D812? I am considering one myself, but still undecided!
  5. Mark123
    Mark123
    Sep 20, 2003
    454
    Belfast
    +29
    I have been very impressed with the 812, it seems a great leap forward from my old yamaha 420. The sound is much crisper and just generally sounds better to my (untrained) ears. IMHO the movement of sounds between left and right, front and rear is fantastic.
    What speakers do you intend to run with it? I am using B&W 603's at the front, and LCR600 centre and Mk2 'Eggs' at the rear. Also have an REL quake.
  6. mevetts
    mevetts
    Oct 31, 2003
    439
    I have only just ordered my first DVD player, so really just planning ahead at the moment! As soon as funds permit I will be diving head first into the surround sound fest! I was planning to probably go for a set of Canton CD-1's, what do you think!
    I would not call myself a sound expert, so do not feel qualified to select a separte speaker set-up? Dilemna! (But a good one, I suppose!)
