PIONEER VSX D811 vs. DENON 1803
Discussion in 'AV Receivers & Amplifiers' started by simon_bai, Apr 27, 2003.
Tags:
  1. simon_bai
    simon_bai
    I was thinking to buy a new amp to match my new B&W VS1/AS1 5.1 package, two choices are around my head now, which is the above two, can anyone tell me which one I shall actually go for? I mainly watch dvds, and I also want to unleash the full power of my speaker package! Also, is it worth to strech my budget to get Pioneer 1011? Is it really worth the £300 extra?
    Another question is if I buy QED's 4mm airloc banana plugs, can I simply use them to terminate the cables and plug into the amps? I have heard someone has troubles with his airlocs to be used with Pioneer 2011. Thanks for any suggestions!
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    No contest IMHO head to head the 811 is better for movies than the Denon (& the marantz 4300 and the yamaha 630). It will be more than powerful enough to drive your speakers.
    Is the 1011 worth the extra - The 1011 is meant to be better than the 811 for music, is more powerful and has some extra toys I didn't think the extra was justified (but perhaps I just mean) but it's down to your own ears for that one I'm afraid.
    I should add that when I bought the amp I was looking for it purely based on movie performance & it's ability to hook up to an integrated amp for musical duties since I don't think av amps in this price range are any good for 2 CH music (The 1803 has no pre-outs so can't be used in my configuration).
    All the X11 pioneers take banana plugs - you just pop the black plugs out of the binding post with a small screwdriver or similar.
  3. simon_bai
    simon_bai
    Any more comments please, am I worthwhile to go for the £700ish Pioneer 2011???
  4. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    YES!!!!!!!!!!!!!!!!
    Best receiver on the streets! (for the price) - equal to Rotel 1055 in IMO but rotel only has 5 channels...
    MCACC rules!
