Pioneer VSX-D2014i
Discussion in 'AV Receivers & Amplifiers' started by shift, Aug 2, 2004.
Tags:
  1. shift
    shift
    Jul 30, 2004
    7
    Has anyone got any idea what this is / more information?
    The only information I've been able to find out about it is from here, I can't even find it in any press releases from Pioneer.
    cheers
    shift :confused:
  2. d.waters
    d.waters
    Aug 18, 2001
    694
    +12
    Yes, I have a similar issue with the 1014. It doesn't make any sense for them to be replacing the AX3 or AX5 because they are so much cheaper, and when the AX5 came out it was quite a bit more expensive than its predecessor, wasn't it?
