Pioneer VSX D2011 Vs Sony STRVA 555ES
Discussion in 'AV Receivers & Amplifiers' started by Lez, May 13, 2003.
Tags:
  1. Lez
    Lez
    Dec 14, 2002
    113
    +7
    I've approximatelty £750 to spend on renewing my old amp.
    Any feed back on the 2 amps mentioned would be appreciated.
    I note in the specs for the Pioneer it has 7 channels, have I read it correctly that this will allow me set up a 7.1 configuration with the speakers.
    Thanks in advance
    Lez
  2. vulkan75
    vulkan75
    Hi lez.This months what hi fi has a head2head reveiwing these amps,both are very very good amps,not much between them at all.
    I am in a similar position as yourself and already owning a sony(940c)cant fault sony's quality.
    However personally i would go for the pioneer(THX auto set-up)etc.
    Others no doubt will differ in their opinion.
    My recc would be buy the mag,read the head2 head,get down to a dealer and arrange a demo,then decide.
    Nice dilemma:D
  3. vulkan75
    vulkan75
    Given yr budget check out denons 3803 aswell:smashin: :smashin:
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Lez ... the only way to decide in terms of sound is to go and listen. They (and the Denon 3803 and others in the price) are very similar in terms of sound quality but they do have differences between them.
    Apart from that its down to comparing the feature lists, appearance, etc and deciding which you prefer.
    Vikki
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    And don't forget Onkyo's TX-SR700E - possibly the best sub £1000 movie performer or Arcam if you want something a bit more restrained that can do movies & music
  7. ChrisNic
    ChrisNic
    May 11, 2003
    1,702
    48
    Thame
    +63
    In my view the pioneer sounds better but the sony's build quality is in another league, depends where your priorities lie.
  8. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    I should get a look at this 555ES then because my 2011 is built like a tank.
  9. ChrisNic
    ChrisNic
    May 11, 2003
    1,702
    48
    Thame
    +63
    I suppose im really talking about the feel of the sony, all the controls and the remote they just feel well made but I hated the controls on the pionner.
