Pioneer VSX-D2011 cut out ?
Discussion in 'AV Receivers & Amplifiers' started by Fjorko, Apr 27, 2003.
Tags:
  1. Fjorko
    Fjorko
    Apr 25, 2003
    510
    Port Elizabeth
    +24
    Can anyone confirm to me whether this amp (as sold in the UK) has the same "shutdown" problems as the US version TX45 ?
    Also is 100W x 7 not a bit weak for an amp of this stature ? Or has it ample power to drive any speaker you can throw at it ?
    Can you bi-wire your fronts with this amp. I can see only two sets of binding posts at the back (i.e. 4 ) for the front speakers, should there not be 8 in total for bi-wiring ? Or do one use two cables on each post ?
    Sorry for all the Questions !
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    No problems, its seems Pioneer sorted it out before releasing it here.
    It should be fine for most 8 ohm speakers but be careful with 4 ohm ones, (not recommended by all accounts)
    Use two cables on each post if you need to biwire, (much easdier with bannana plugs)
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,343
    Southsea, UK
    +101
    Pioneer gives you an option to bi-wire the front speakers by using the back surround channels of the amp.
    Of course by doing this you can only get 5.1 surround instead 7.1.
    Something I considered doing myself, but I decided I'd rather have full surround capabilities rather than bi-wired fronts.
  4. meep
    meep
    Apr 22, 2002
    708
    Ireland
    +83
    This is actually a bi-amp option - you would be driving each speaker with two amps rather than a single amp if the two cables were attached to the same posts.
    Peter
